Stihl Fs94
Kodie's Lawn Service
Well its finally here the new fs94 is out i stop by my dealer today an they have 10 in stock an there selling for 360 before tax an i am also told sold drive shaft an 29 cc motor cant wait to try one out. :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
davbell22602
Got any pics of this FS94? I like the FS85 loop handle.
Ric
It's actually 24.1 cc and weighs 10.2lbs spec's below
STIHL FS 94 R
Specifications
Displacement: 24.1 cc
(1.47 cu.in)
Bore: 35 mm (1.38 in)
Stroke: 25 mm (0.98 in)
Engine power to
ISO 8893:
0.9 kW (1.2 bhp)
at 8,500 rpm
Idle speed: 2,800 rpm
Cut-off speed (rated): 9,800 rpm
Max. output shaft
speed (cutting
attachment): 7,290 rpm
KubotaJohn
I am a Stihl Dealer in Keystone Heights and we received the FS94r about a month ago and this machine is awesome, has a sort of "cruise control" and everything. nice for when you are doing low speed trimming
davbell22602
How much does this FS94R weigh compared to the FS85R?
Ric
The FS 94 is 10.2lbs. Personally I don't understand what all the hype is all about especially when you can buy the FS 70 with a 27.4 cc engine and it weighs 10.6 lbs for $279 which is almost a $100 less.
without cutting tool and deflector
FS 80 R
1)
10.8 lb (4.9 kg)
FS 80
2)
11.5 lb (5.2 kg)
FS 85 R
1)
11.0 lb (5.0 kg)
FS 85
2)
11.7 lb (5.3 kg)
FS 85 RX
1)
10.6 lb (4.8
davbell22602
I guess the hype is for the cruise control feature.
KubotaJohn
the cruise control is nice especially around rock beds and painted objects. It's also not a 4 mix like other stihl trimmers. They went with a two stroke with that air intake system that is similar to red maxes intake.
Ric
If I'm going to spend $360 plus, I'll get the FS100RX. It's a 31.4 cc engine and weighs 10.8 lbs, you'll have twice the machine for the same money.
