Stihl FS45 string trimmer bump knob - cannot remove
dukerocks
I'd like to keep that flex cable from turning when I try to twist off the nut. The only place I can reach the other end of the flex cable is at the motor drive shaft.
Carscw
You are not going to remove the nut by holding the flex cable. You will just twist the cable and will need to replace it.
dukerocks
So, do you or anybody have a practical solution for removing the nut?
Carscw
Not all nuts are left handed.
I have some trimmers that the nut comes off going counterclockwise and others that come off going clockwise.
Did you try both ways ?
If the head turns counterclockwise when trimming then the nut comes off clockwise.
EngineMan
Should there not be a hole in the deflector for a locking pin to go into...!
dukerocks
WOW, that makes a lot of sense, I'm hoping you are right about that pin. I did hear something snap when I was using opposing pipe wrenches. I will check that out. Is there a parts diagram maybe showing that pin? Thanks
Fish
No, no pin on the curved shaft
Fish
Take that back, there is a hole for a lock pin!
Fish
Not a lot of plastic/meat there, but it may hold.
dukerocks
Please, somebody correct me if I'm wrong. It seems I should cut off the entire black plastic cutting head to get to the bottom side of the nut?
