davbell22602
- Nov 27, 2011
- Threads
- 152
- 1,324
Need 2nd on my Stihl 034 on if its crank bearings or something else. Been having issues with pulling the rope on a cold start. Its hard to pull unless I stick my foot in the opening where the trigger is to brace it. When its being pulled is makes a cracking sound. Then after 5-6 times it pulls normal. I took recoil starter off and it pulls out fine when off of saw. I can turn the flywheel by hand but its tight at first like something is sticking. I described this same issue to friend thats been in the business longer than I have and he saying its crank bearings need replaced.
