davbell22602
- Nov 27, 2011
- 152
- 1,324
No older Stihls saws run 32:1 my grandfather has an old 088 that is 32:1 (in the Manual) Now the newer ones have 50:1
Stihl mix is 50:1 now. My 034 manual says to use 50:1 mix.
So.. The noise is in the recoil when it's off the saw? Then I suggest maybe the central post of the cover is worn so the rope pulley isn't always pulling true, binding it against the side cover and spring, making it screech.
I took apart the recoil. Cleaned the housing pulley and spring. Pulley has about 16th of a inch wobble to it. Spring was really dirty. Also found that when I cut the rope it didnt retract around the pulley like the others I replaced.
