Beamster
- Apr 22, 2019
- 8
- 56
Our Toro Briggs Quantum 125K02-0182-E1 will start after priming but stalls very soon thereafter. It will restart (and does the same) repeatedly only after repriming each time. It's fresh fuel, the tank was drained and fuel line changed. Nothing of surprise in the float bowl. I did find a mouse nest under the top shroud and that was all cleared out but made no difference. This is the first running issue, other than a flaky governor causing a surging like running condition that I have lived with, after probably 20 years of ownership. Any ideas? It's old enough to not spend a fortune changing parts, but then again I don't like throwing stuff out.
