- Sep 24, 2017
- Threads
- 280
- 6,783
a lot of NGK fakers out there. go to a local auto part store that carries NGK etc
I don't think so. As easy as mower plugs are to change, go with standard ones.I have a Scag Liberty 48" with the Kawasaki FR651V. All is well in terms how it runs, but at some point will change the spark plugs. Do the iridium plugs have enough benefits to justify the higher cost?
My spark plug(s) are better than your's because I draw little smiley faces in the insulators! So there! :-DYour spark plug isn't better than my spark plug because the T.V. says so...
but does you lawnmower run under lean burn conditions at 30,000 feet ?I'd say iridium are for sure "better" technically and they will last longer assuming you have no negative factors affecting the plugs like overheating or fouling. With that said - will you EVER realize any real benefits to justify the costs? Probably not.
Our airplane has a 5.9 liter 6 cylinder air cooled engine making 200hp turning 2700 rpm with dual spark plugs and dual independent magneto fixed timing ignition. Fairly similar to a mower engine in hp per liter and RPM. We run iridium plugs in it because of significantly longer plug life, slightly better low idle smoothness (maybe), easier starting (maybe), and reduced maintenance because the electrodes for them are smaller and re-gapping isn't required. Regular copper plugs last ~400 hours in an aircraft engine, and iridium plugs (also known as "fine wires") can last up to 2000 hours. It's worth it on the aircraft despite some absolutely eye watering prices.
I wouldn't bother on a lawn mower engine though despite the technology being superior. It just doesn't practically make a big enough difference and swapping a plug on a mower every 250 - 500 hours and takes all of 2 minutes and will probably never save you money or hassle.
Yes it's better, no you probably don't need or want it.
You have problems with either your fuel quality or with your ignition.My spark plugs suck, Why do they put resistor plugs on mowers? I'v had 6 mowers with bad plugs this month. Mostly NGK r
I draw lightning on mine. I swear my riding mower cut quicker when i painted flames on the sides.../sMy spark plug(s) are better than your's because I draw little smiley faces in the insulators! So there!
Dang! Bested again! Lightning AND flames!?I draw lightning on mine. I swear my riding mower cut quicker when i painted flames on the sides.../s
This ^^It's a lawn mower engine. Iridium plugs will make no difference, same as using premium fuel will make no difference. But, it's your $$
