Thank you so much for you timely response. Let me answer your questions using your numbers:
1. Its a Scotts 20 hp made by John Deer S-2048
2. Its a Kohler command 20 #2408301
3. yes, absolutely nothing happens
4. I use a multi-meter to test circuits and I just replaced the 12 volt battery and it is showing 12.5 volts
5. Last winter I never tried to start it until I had replaced all the old gas with fresh fuel. It ran great all winter
I pulled the switch and cleaned it. I identified all the lead markings. I tried to bypass the switch. I tried to connect two unconnected wires - a red to a white (that created a spark). I have started it dozens of times last winter. please see attached photos.
Well now we are getting some where
Good news for you is I have that manual and there is only 1 wiring diagram so I will post it below
Bad news is it is from a locked file so it is a screen shot which are never as clear as they could be
So the las thing we need to know is which ignition you have as there were 2 different ones used as depicted in the far right section
The Smart Advance ( called SAM ) and the plain magneto
To work out which you have remove the blower housing and look at the coils , only 1 white wire = std magneto , 2 wires ( yellow & brown ) = SAM
Worse news is as I predicted the magneto kill wire is the white while so if you connected that to power you have just cost yourself $ 80 to $ 150
JD use a 30 amp fuseable link between the battery & the alternator wire for recharging and a 15A fuse to protect the wiring on the red wire to the key switch.
I will guess that the extra red wire on the battery , the one that does not go through terminal cover , is a 1/2 wits attempt to overcome a blown fuseable link ( heavy blue wire )
Now the big question is can you understand this wiring diagram
From my time on various forums it appears that less than 0.01% of American can actually manage this basic high school education feat .
If not let us know so we can walk you through it and hopefully fix your butchered mower
Please note the K1 START RELAY is the proper name for the solenoid
To energise the starter the purple wire needs to be battery voltage when the key is in the start position.
