Thin metal can be cut with a hacksaw if you install two blades into the frame with one backwards (NOT UPSIDEDOWN) The opposing teeth will act like a file--slow, but has worked many times for me.
Of course, in most cases, metal snips, nibblers, and abrasive blades are used for this, but some special circumstances call for this procedure.:thumbsup:
The correct blade, for cutting any thickness of metal, is to have at least two teeth in contact with the material during cut. Since I have never seen a hacksaw blade with that many teeth, this is as close as you can get.![]()
That's something I've never thought of, but I'll bet it beats a single bladed approach.!:thumbsup:
