Mower manic
- Aug 1, 2011
- 3
- 228
How do you remove the plug wire when the engine is a diesel? :laughing:
If you really want to remove a plug wire on your diesel, use a sharp knife and cut any wires directly adjacent to the fuel injector. There is no need to re connect these wires after you replace the blade or blades, your machine will run fine as log as the temperature is over 40F.
Good luck:tractor:
