SOLVED
SOLVED ! ! !
FIRST
I removed the solenoid and blocked the hole with a piece of rubber and a clamp. ( I couldn't find a bolt with the same thread) Still did the same stall and surge routine.
replaced the solenoid.
I called the place that sells the 17.5HP XP 620, Not where I bought it from, but their competitor.
The place I actually got it from are arrogant and rude, I won't name them, and I will never go back there again.
... actually just another place that assumes that everyone is a two bit amateur and never think that in a million years that you may actually have more experience than them.
But the really nice knowledgeable people who respect you as an equal human I will name because they always go above and beyond their duty to help you with your dumb questions.
Thanks :thumbsup:Jonno and Johno:thumbsup:
I asked if he sells many replacement coils which he said, "yes".
I asked, "is it because they fail?"
He said that they sell a lot because people wire them incorrectly and fry them he couldn't recall a case where he sold a coil which had failed. That was nice to hear.
OK so I wasn't going to order the coil.
We went through a few other possibilities, all things pretty much discussed here.
Then he said that a few times they made the fuel inlet hole a bit bigger with a 5/16th drill bit.
Maybe I misheard him about the 5/16" bit. I didn't really go into great detail of what he was saying. I thought that I'll work it out when I look at it.
So the 5/16" thing might be an entirely different mod.
Before I did anything I started it up and as expected it was surging. As I have the air cleaner box off (filter still attaches) and the cowl off, I had easy access to the choke and throttle
so I very very slowly closed the choke and I got it to stablise for a few seconds. I then did it again, then after three times I was sure it wasn't chance.
I pulled off the carb again
saw that the inlet has a JET in it?
So I removed the inlet elbow.
I made the jet a little bigger with a 1.4mm drill bit
You can't quite see the jet hole in the pic but I only made it a little larger
of course, Blew it out with air.
Then in the hole, where the inlet elbow is pressed into, I could see what looked like a black piece of foam.
I got a tiny bit of wire to see if it was a filter or just dirt.
IT WAS DIRT
I blowered it out, and discovered there is a
tiny metal mesh grille in there WT ?
Assembled and Works Awesome
.........................................WOO HOOO
I am sort of happy, it was a very frustrating but rewarding journey.
You could say a sweet and sour victory.
This year I am defiantly going to put a blower, nitro, roller cam and rockers on this Chinese Engine and go to the yearly mower races and whip their racist arses....
