reynoldston
- May 23, 2011
- 5,705
ok, guys, I will try my best to follow the diagram I have (scanned) and follow the colors. I will also check the metal strips, like was mentioned. Sheesh, what a pain, but gotta do it,,,,,,,,,,,,,
I wish we had consensus on to use light or multi meter. Light is easier. I appreciate your helps. I wil let yous know what happens.
Nothing wrong with using a light, The advantages of the meter it tells you the amount of voltage. I will use a test light when I don't have a meter and you can do a lot with a test light. Don't let yourself jump around on different cirricts, only one at a time. Take your time, relax, and enjoy what you are doing and you will have that good feeling when you find the problem. :thumbsup: It helps me to get a good rock station on the radio as I work. Just repaired a bad ETC switch on a off road bike this pass week end which took a fair amount of time finding.
