- May 6, 2010
- 12,024
It's Ok Mackie. We all have bad days, and I also got carried away, so I also apologize. I was also doing some digging and came across a patent for a small engine regulator/rectifier that could be connected to the battery, but not cause excessive discharge. The patent date was in 1986.
Kohler has for several years said that their regulators should be connected directly to the battery, or the battery side of the starter solenoid. Mostly to reduce the chance of power spikes. Remember Kohler has been fighting power spikes to their ignition modules, as well has roasting ECU's on the EFI engines. Which was the main reason for all the electric changes to the ignition modules over the years.
1.4 milliamp sounds about right, The Briggs regulator requires a minimum of 5 volts input for the output side to work.
