Hammermechanicman
- Jan 10, 2020
- 69
- 3,908
Do you mean a mechanical pump that feeds fuel to the injector pump? If so disconnect the line coming out and crank engine and see if fuel pulses out. If you can test fuel pressure check for around 5 to 7 psi out of the lift pump. Do you have any fuel in the crankcase oil? If so bad diaphragm in the lift pump.
