Will get them postedIt will have an injection pump for the fuel injectors.
Will need all the equipment numbers including the engine make and model numbers.
All I see is one filter. When filter is changed does air get into fuel injection system? I have changed the filter before and did not have to bleed air out of fuel system. I will bleed system, easy enough to do to see if it helps. Thanks for answer, you have helped me before.Most Kubota’s have two fuel filters, in-line very close to each other. Don’t know if your Grasshopper has two?
No but I will, thanks.Usually when a diesel dies from fuel exhaustion, there is no restarting it until you re-prime the system. Did you re-prime after changing the fuel filter?
Most kubota's have 2 fuel filters and an electric fuel pump and then the injection pump. It sounds like the electric pump is failing. I have seen that symptom on kubota powered equipment a few times and it was always the electric pump. Be careful if it is the electric pump. Running the injection pump with no fuel can damage it.
