Removing PTO clutch on Grasshopper 725D
MBFTech
I've searched and watched several videos on removing this clutch, but none really show or describe HOW to get the thing off the shaft without damaging stuff (pulleys, shaft, etc
I removed the belts and bolt on the back. Now what? The back frame prevents using a gear puller (local GH dealer said never use a gear puller).
Does the electric clutch come off separately from the double pulleys?? (Noticed the Xtreme clutch comes with new pulleys)
I'm as good as the next guy using excessive force with hammers and crowbars, but there must be a better way.
Thanks,
Ken
Hammermechanicman
I use a bolt that has been drilled in the head about 3/8" deep. Bolt is installed without a washer and i use an air hammer ont the bolt. Never had a problem getting a clutch off.
MBFTech
Thanks for the quick reply.
The only place for the bolt is in the shaft, so you use the ait hammer to vibrate the shaft while pulli g on the clutch?
Pardon my old brain if I missed something.
Ken
MBFTech
The clutch is off. Like some things in life, a little heat and vibration works wonders.
Thanks
sgkent
he probably meant this
Funny how things happen
I am waiting for a new Warner 5218-248 clutch right now to go on a Z master .
In this case the top bearing had collapsed and siezed onto the PTO shaft .
The one comment I will make about DonyBoys video is the use of the bolt to bear against .
If you do this you should double nut the end about 3 or 4 threads in so when you screw it into the PTO shaft the nuts bear against the end of the PTO shaft to take the load & prevent damage to the end of the internal thread , which you will of course not notice till you are under there with the clutch in your hand , getting heavier by he second wondering why the bolt won't catch the threads .
DO not use the original PTO bolt for this job as it is only a grade 5 and can be bent , go get a grade 9 bolt .
As an aside , I usually put a short allan headed bolt that is fully threaded into every shaft that I am going to put a puller onto to protect the threads .
Pullers work better when driven by an impact wrench ( even one you hit with a hammer ) as the jerky application of the torque tends to shock stuck parts apart .
Ian_Robinson
Detailed Clutch Removal Instructions:
The steps according to the manual:
1. Remove clutch shield
2. Remove clutch bracket (below frame, fits into slot on clutch housing)
3. Loosen spring tension on belt idler pulley and remove drive belts. (Alternative -- 15/16" socket on breaker bar)
4. Unplug wires from clutch. Loosen clutch center bolt. Slide clutch back [Good luck with that] and remove hex socket bolts to remove clutch and stub shaft together.
5. Remove clutch from stub shaft. [You may need to use a small hydraulic press]
6. Replace in reverse order.
Removing the belts:
The manual says to remove the idler pulley tension spring to remove the drive belts. I've used a pry bar or long screwdriver as shown in this video, but the safer and better practice is to use an 15/16" socket on a breaker bar because you get better leverage and a safer grip.
Idle Pulley Spring:
The spring tension is strong, so if you remove it (which may be necessary) you will need tools like needle nose pliers, vice grips, etc. to keep a firm grip on it as you pull. Be careful because you can get hurt when the grip fails. It is difficult to remove and even more difficult to reinstall. Leather work gloves may protect you from scrapes and cuts.
Removing the clutch:
The 700 series clutches are pressed onto a stub shaft and the stub shaft is mounted to the end of the crankshaft with five hex-socket machine bolts. The owner's manual states to remove the clutch you remove the hex-socket bolts first. There is just enough room between the back of the clutch assembly and the stub base to insert an "L" angled hex wrench. (Sorry I don't remember the size.) The bolts are going to be tight. Use penetrating oil. You may need a small diameter, short length of pipe to fit over the allen wrench for leverage.
Once the bolts are removed, the clutch & stub shaft can be lowered straight to the ground when the clutch electrical cable connector is disconnected. The other benefit of removing the stub shaft first is you don't have to FAIL trying to get the clutch off the end of the stub shaft after it's jammed against the rear of the frame.
Inspect the stub shaft.
With the clutch off the stub shaft, inspect both ends of the shaft part for wear. If you see a groove about the same width as the bearing race, that is caused by the inner part of the bearing grinding down the shaft. If you see a groove, order a replacement stub shaft. Check the key slot for wear and damage. Don't forget to reinstall the stub shaft spacer.
Installing the Clutch:
Recommend you put some anti-seize compound on the clutch shaft before installing the clutch.
Remember to align the key slot of the stub shaft with the key slot of the clutch before sliding the clutch onto the stub shaft.
Inspect the gib key (a tapered key with a tang on the end). Look for wear and damage and replace the gib key if damaged or is sloppy in the key slot.
Inspect the clutch retaining bolt. If the flats of the bolt are rounded, replace the bolt with a high-grade one. Torque the bolt to 55 foot pounds. Rest a pry bar or a big screwdriver onto the right-side frame and insert it into the teeth of the flywheel to stop it from turning under torque.
Remember to have the clutch bracket (below the rear frame member) inserted into the clutch housing to stop the clutch from rotating when the clutch is engaged.
Installing the belts:
You have to put the belts on over the clutch bell pulley and over the driveshaft pulley. The problem is getting them onto the idler pulley. Use the 15/16" socket and breaker bar. If you removed the spring, it can be difficult to stretch. One solution is to buy a long "eye" bolt (a threaded rod with circular end). Drill a hole through the left frame near the original spring-end fitting, insert the eye bolt through the hole from the inside and connect the eye to the spring. Add a washer and nut to the threaded end, and tighten to stretch the spring.
(I saw an interesting Y/Tube video where the author secured one end of the spring into a vise, then bent the spring to open space between the coils. He inserted coins (or washers) into the space of each coil. He turned the spring around to bend in the other direction and inserted coins on the new side to make the spring straight. The coins lengthened the spring, after which he removed the coins.)
Burnish the new clutch
Burnish by engaging clutch for 30 seconds, off for 30 seconds, on for 30 seconds, etch for 5 times at half throttle, the same on-off routine 5 times at full throttle.
