True, but the picture posted by the OP at post #3, the regulator only has one mounting bolt not two for the 698315IL if you had looked the image I posted it gives you the regulator for batteryless systems. PN 698102 superseded to 698315. It has a large electrolytic capacitor that serves as a mini battery to provide voltage feedback for the regulator.
Installed at the factory for a battery system is a very good possibility. His engine does come with the steel ring gear flywheel and list an electric starter on the IPL.I understand that but it is probably the reason it is not working as someone installed the wrong one earlier. Or it was installed at the factory for a battery system. All I can go by is the info that Briggs provides.
Some techs think just if it connects it is the right one.
Please see my description of the troubleshoot I have completed at the bottom of the post. Is this thinking correct? I worked on helicopters for 24 years. But I am very weak on electrical (But learning!). The last question would be just to double check about the single mount bolt vs 2 bolts. If this is the correct rectifier and there isn't one with a single bolt, I will just drill and tap a second mounting hole.I understand that but it is probably the reason it is not working as someone installed the wrong one earlier. Or it was installed at the factory for a battery system. All I can go by is the info that Briggs provides.
