B benson145 Forum Newbie Joined Aug 29, 2023 Messages 7 Aug 29, 2023 #1 Hello, mower will only start if jumped, battery tested at 12 volts before starting and at 14 volts when running. Checked the battery leads, no corrosion. Anything else that would cause this?
R Rivets Lawn Royalty Community Leader Joined Mar 11, 2012 Messages 16,285 Aug 29, 2023 #2 Measure the battery voltage while starting the unit. If It drops below 10 VDC, the battery is going bad and needs replacing.
B benson145 Forum Newbie Joined Aug 29, 2023 Messages 7 Aug 30, 2023 #3 Rivets said: Measure the battery voltage while starting the unit. If It drops below 10 VDC, the battery is going bad and needs replacing. Click to expand... So that's measuring with it trying to start on it's own, no jumper cables?
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Messages 24,995 Aug 31, 2023 #5 Jumped or bridging the solenoid terminals Totally different set of symptoms for each case
B benson145 Forum Newbie Joined Aug 29, 2023 Messages 7 Aug 31, 2023 #6 Voltage dipped to just below 12 when trying to start. Checked it with jump starter connected and was at 15.
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,529 Location Pluto Aug 31, 2023 #7 Need the seven model number to look up wiring diagram.
B benson145 Forum Newbie Joined Aug 29, 2023 Messages 7 Aug 31, 2023 #8 Bought it used, someone removed the sticker with model number, believe it is the wiring diagram on this one. https://www.thepowerportal.com/ipls/ipl.htm?md=1693529~_IPLURL_LO.pdf
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,529 Location Pluto Aug 31, 2023 #9 Strange Power Portal just send me off to a Snapper mower. The closest I can get is the 1693528 and 1693530.
B benson145 Forum Newbie Joined Aug 29, 2023 Messages 7 Sep 1, 2023 #10 This is from the power portal page, not sure what to replace, seems like it needs more cranking amps, battery is an interstate.
