Regent 15 hydro
benson145
Hello, mower will only start if jumped, battery tested at 12 volts before starting and at 14 volts when running. Checked the battery leads, no corrosion.
Anything else that would cause this?
Measure the battery voltage while starting the unit. If It drops below 10 VDC, the battery is going bad and needs replacing.
benson145
So that's measuring with it trying to start on it's own, no jumper cables?
Jumped or bridging the solenoid terminals
Totally different set of symptoms for each case
benson145
Voltage dipped to just below 12 when trying to start.
Checked it with jump starter connected and was at 15.
Need the seven model number to look up wiring diagram.
Strange Power Portal just send me off to a Snapper mower.
The closest I can get is the 1693528 and 1693530.
benson145
This is from the power portal page, not sure what to replace, seems like it needs more cranking amps, battery is an interstate.
