Ric
- May 7, 2010
- 5,765
OP back.
Embarrassing cut tonight with my SD 54.
I was on vacation this week, so my lawn went 8 days since the last cut. We had two significant thunderstorms this past week which brought some torrential rains too, so there was some growth.
I'd say I was between 5 and 6", cutting at 3". So in some cases I was taking 50%+ off the lawn. Not ideal, but I would have hoped not overwhelming for the mower either.
Attached is what I got. This is still with the super high lifts and a squared-off discharge chute.
I'm back to running the Gator blades and I made an arbitrary increase in engine speed tonight. Not sure if it's 3600 rpm or above (lever is about 1/8" from the end of its travel in the cam), but there's not much more room to increase speed beyond where I have it.
Same result. TWO days worth of growth (two big downpours over the last two days) and I still have rows of visible clippings and some smaller clumps. I was trying to determine if it was throwing the clippings further (before, most clippings were landing between 3 and 5 feet). It might be a hair better in terms of distance thrown, but hard to tell.
Your trying to fix a problem with a mower when the mower isn't the issue. The mower is doing all it can do. You can't cut grass that's 5 and 6" high taking 50%+ off the lawn and not expect the outcome that your getting. Your deck wont handle it. You need to increase the frequency of cutting to no more than every three days until you get the lawn under control. I'd start at the top of my height settings and cut at a 3 day interval bringing it down a 1/4" at a time until you get the lawn cutting to a 3 1/4" height and at that point re-cut the lawn when it gets to a 4" height at your 3 1/4 setting and you''ll solve your clumping issue and have a better looking lawn.
