PVHIII
- Jun 13, 2013
- 15
- 289
I need to read up on the Fastrak models - I believe there used to be a base model and an SD, not sure of the differences between them, and I know there have been changes for 2015. I'm also not sure which of them he was planning to let me demo. I do know that the one he pointed to when he and I were speaking had the FR691V on it, which is the same as my Raptor SD.
The FR series engines are on the standard Fastrak....FS series is on the SD edition and yes they still build those and now (on the new models) in order to get the FX (commercial) series you have to step up to the SDX model which is a new model introduced in 2015...I have a 2013 FTSD...they came with FX series engines on them back then...some changes to the new mods are a deeper deck (which is good) bigger tires....the SD edition. now comes with ZT 3400 transmissions instead of the ZT3100 which I have on my FTSD both are commercial grade...mine also has a chain hung deck which is very important to the point where I feel it can't be over stated...all new FT models have bracket hung decks...in order to get a chain hung deck now you must step up to the X-one series... there are some other minor differences but I feel these are the important...the standard FT would probably suit your mowing needs just fine...however I have a history of going bigger than I need...if it were me I'd go for the SDX or at minimum the SD model.
