am i going to regret getting a raptor sd 54? i will mainly being using it to cut tall grass. maybe 6" to 1' tall, empty lots.
From my experience I would say will you be happy with it, talk to mooch and PV and they will tell you will hate it. Why don't you demo one for a couple days and see for yourself.am i going to regret getting a raptor sd 54? i will mainly being using it to cut tall grass. maybe 6" to 1' tall, empty lots.
And that is why I went with the 35 HP when I upsized to the 72" Super Z.That's the main reason I went with the 48" instead of the 54"...POWER...I feel like mine would be under powered if I had the 54"...I have plenty of horse's for the 48".
If you haven't read this whole thread you may want to before you buy, Take a good look at the photo's and you can make up your mind.
If your going to attempt 6" to a 1' foot tall grass my choice would be a good 48" walk behind, it would do the job well. It just depends on what type of cut your looking for, I wouldn't attempt foot tall grass with a ztr.
well, the lawns i'll be cutting wont matter how they look. lol
these raptors cant cut any worse than my old home depot cub cadet, could it?
walk? i suppose i could use the exercise, but it ain't gonna happen.![]()
...mine also has a chain hung deck which is very important to the point where I feel it can't be over stated...all new FT models have bracket hung decks...in order to get a chain hung deck now you must step up to the X-one series...
Would you kindly expand on chain over brackets?
Why is this feature so important?
The chain hung deck still has forward mounted height
adjust "brackets", yes/no?
Cheers
walk? i suppose i could use the excercise, but it aint gonna happen.![]()
