mhavanti
- Oct 12, 2014
- 924
Boyler,
After watching two hydro rebuild videos from start to end and strange enough they both mentioned the "only difference between 2800 and 3100" is the extra valve. Mine is getting the valves.
The Fastrack across the street I rode, I used the GPS to see what his ground speed was. It is supposed to move at 9 mph. It will only move at 8.8 but then, he could use some tweaking on his sticks and adjustment rods more than likely. His hydros don't whine as loudly as mine either.
My SD only moves at 6.8 mph and it is supposed to move at 7.5. I also have not tweaked mine for the extra speed. Although I did tweak the left side to speed up to the right. There seems to be enough travel on all the adjustment areas of the rods and the brackets at the hydros to get the speed it is supposed to run. May do that sometime this summer if I can find the time for it. I don't like being outrun and I don't care what it is on. I don't like finishing second. lol
If I can get mine to 9, I'll be happy at that time, however, after it sees 9, I'm probably going to want to see 10.5 mph.
I really want is forty foot wheelies, but, don't foresee that anytime soon with a 24 horse motor. lol.
Max
Max
