mhavanti
- Oct 12, 2014
- 924
Here is the scale up of the soon to be available removable Raptor grass catcher deck filler block off plate. The plate will have either 5 or 6 tabs that a screw will go thru, then thru the deck and into a welded nut on a full tab below the deck. This is for those that have totally removed the reinforcement bar and those that would like to give themselves a bit more safety to help keep posts, legs, etc. out of the open indention above the blade.
This plate is simply a scale up. It is incomplete as far as the bolt on tabs.
Give me your thoughts on the product that I should have ready in the next few days.
Max
Max
