Same for my little town. You buy it from the dealer here, you own it. Talks good service, but, when you call or go by, its like he has had a really bad day. While you're there, if a new customer comes in talking purchasing a new mower, his bad day sure seems to change exponentially. I must say, he does have a ton of service from his commercials and does treat them well. Residential owners don't need to call him.
He only services what he sells. Box store sells, he won't touch them at any price.
I left two for three months to serve my country. Talked him into changing the oil, clean the carburetor, lubricate the pull rope spring return, and change the air filter on a Honda Self Propelled walk behind.
Got back to town, went to pick it up, he claimed he didn't have it. I argued with him for a while, then a light bulb clicked and he said, oh yeah. I remember. He walked out to a lean to canopy structure, brought the little Honda out, filthy, covered with sand, leaves, cut grass, etc and black from mildew looking crap. Didn't hardly recognize the unit. He said it was 85 bucks for everything and it is ready to go and had to replace the carburetor because he couldn't get a rebuild kit for it. I have taken the carb apart three times, cleaned it and reused the gaskets each time with no problems.
I paid him, loaded it up, took it home and pulled the dip stick. Black as tar, original oil and it turns out the oil hadn't been changed. Checked the carburetor where I'd used an engraver to put my initials. Yep, you guessed it, initials still there. It wouldn't start, gasoline smelled years old. I couldn't hardly pull the rope. Original air filter still in place with my name written inside between two pleats.
I called him and he said I was wrong and not to bring him any more off brand mowers if I'm going to accuse him of .................. Since I was home for a few days, I took care of it in a few hours (soaking the carb took the longest time) and it runs perfectly. Removed the recoil / fan housing, cleaned the recoil, lubed it and now it is easy to pull the rope and it recoils correctly. I lubricated the cables inside their housings and they both operate smoothly once again. As you can tell, the little Honda is hardly ever used and sits inside a garage taking up space. Just like it to run when I'm ready to loan it out.
I purchased my RSD60 from this dealer earlier by a couple of months and he agreed to service anything I brought him before I purchased the RSD. Well, I learned a lot with this dealer. Lowes now handles the mowers and will actually have mine serviced if I were to need warranty work on the dealer sold product. How's that for customer service?
Now, as far as ride, Tom removed the middle spring from under his chair to smooth out his ride. Runs his tires at 8 pounds and I know that will smooth it out tremendously. Good luck on improving your ride.
