reynoldston
 - May 23, 2011
- Threads
 - 92
 - 5,705
Wow, thanks for the history lessons in 2 stroke oil. So they actually came out with the engines before the 2 stroke specific oils to use in them? Well, on second thought I guess that makes sense. Just out of curiosity what happens if you run a higher oil content mix than required, i.e. 40:1 in a 50:1 motor? Will it just not run as well and foul the plug or will it likely damage the engine?
40:1 or 50:1 I can't see where it would make any difference. Now if you get it down say to 20:1 it would just foul your plug and if ran for long periods you would get a lot of carbon build up and problems like carbon on the piston hitting the head. The company that made and design the engine knows what oil to use and how much and for what it cost why not use the right oil and amount?
