davbell22602
- Nov 27, 2011
- Threads
- 152
- 1,324
Blade only rubs deck when pushing it to mow. Checked blade and its not bent. Same with crank. Blade doesnt rub when sitting still when engine is running. Any ideas or thoughts?
Wipe off the fresh cuttings to locate the bare spot. It should have scrapes from the blade hitting the deck. If you are sure there isn't a crack, then I would check the spindle. If it's vibrating after hitting the deck, you will need to tighten or replace the spindle. (it will need tightening if the blade is moving around) You may also want to check that the bearings are in tact.
OEM Replacement Parts | DIY Repair | eReplacementParts.com
