FredBacher
- Sep 6, 2020
- 2
- 23
I knew it wasn't working when I got it and figured I could give repairing it a shot.
Here is where I am at.
There it is, exciting right?
So far I have taken apart the carb, cleaned it, got a Zama spec re-haul kit and replaced the diaphragms and screen, I also swapped out the fuel filter, primer bulb, and fuel line going from bulb to carb as it was cracked and gave it all new fuel.
So as of now the primer bulb is working, I see it sucking up the fuel, the spark plug us working, and that's it. I pull the handle and get nothing. I tried adjusting the L and H screws back to what I read was default, which is all the way in then 1 and 1/4 turn out, and nothing.
Everything seems clean and in working order but we aren't getting started. I close the choke and have tested it by pulling the trigger and I see the lever snap to the open position.
What do you all recommend I look at now? The starter cable pulls fine, it kind of gives the expected shake you would hear when you pull something. Outside of replacing the whole carb with an after market anything I can do now? There isn't like an obvious shut off switch or something I am missing, right? The adjustment screws were loose when I got it so no idea what's been happening there.
