can someone tell me what size that center nut is and do you loosen to the left or are the threads different direction
I don't have a socket that big and have to borrow one
As soon as you remove the nut on top of the flywheel, you'll be able to see if the key is sheared.
I don't have an ignition so I jumped from the starter.it will turn over without the plug but once you put the plug in and has compression it will barely move.i can turn the flywheel screen by hand and of course it gets harder on the comp stroke but I can still turn it.brought it to a shop but they tested it but it wasn't tested under a load.wondering if advance auto can test it?i live in the country and we have one shop so I need to try to fix it myself
I don't understand what you doing when you say jumped from starter? What did the shop test, not under a load? What are you testing at Advance Auto, the battery?
When I pull a flywheel I use a puller, but in a pinch I have pulled flywheels by prying under the fly and hitting the top of the crankshaft with a hammer and punch, but if you do it this way use caution because you can do damage.
