Not to start an argument.....
GrumpyCat
Did a test recently. I have a 5 gallon can that is appropriately dosed with StarTron.
Which is in the jar on the right.
Jar on the left is straight pump gas.
Both jars filled filled up to 1 cup mark, and I added a eye droppers worth of water, so each jar has the exact same amount of water in it, stirred both jars after adding water, set for 1 hour. Phase separation has occurred on the left, on the right.. I see no phase seperation...which is one of start trons claims, it changes the surface tension between the water and fuel.. My next test is to put the startron/fuel/water mix into 4 cycle blower that I occasionally use and see if it will actually Run it...
So you are bragging StarTron treated gasoline will carry more water into your engine than straight pump gas.
How is this beneficial?
How are you to burn, water?
Scrubcadet10
Moderator
Staff member
We're dealing on the atom/particle scale here, the water is dispersed so you don't have a clump of water that kills the engine.. you may get a performance decrease, maybe... the 4 stroke blower didn't seem to mind.,
Gym123
Small amounts in the atomized fuel/water mix will burn, but not necessarily well. If a lot of water is in the fuel mix, it's going to lose power. Ideally, the fuel filter(s) do the job needed. Boats often have so much water in the tank that a fuel/water separator is needed and when they're dumped, it's not uncommon to see that it's half full of water. These are the same size as a Pennzoil PZ-3/AC Delco PF25 oil filter.
