- Sep 24, 2017
- Threads
- 280
- 6,787
Did a test recently. I have a 5 gallon can that is appropriately dosed with StarTron.
Which is in the jar on the right.
Jar on the left is straight pump gas.
Both jars filled filled up to 1 cup mark, and I added a eye droppers worth of water, so each jar has the exact same amount of water in it, stirred both jars after adding water, set for 1 hour. Phase separation has occurred on the left, on the right.. I see no phase seperation...which is one of start trons claims, it changes the surface tension between the water and fuel.. My next test is to put the startron/fuel/water mix into 4 cycle blower that I occasionally use and see if it will actually Run it...
