PTmowerMech
- Apr 16, 2018
- 421
- 3,218
Maybe it would make more sense if you think about the spark as a heat source. The gas is ignited by that heat source. Water is a coolant. So the water cools the spark aka heat source below the temperature required to ignite the gas. Therefore the gas doesn't ignite therefore no run. Also if the spark plug gets wet with water and water is conductive of electricity it grounds out the spark.
A combustion chamber is cold when an engine is trying to start.
About the water, keep in mind, I'm only talking about a small amount of water in the float bowl. Due to sitting and collecting moisture from condensation.
That would get sucked up into the intake fairly quickly. Especially if the carb is choked. Then once the gas starts getting sucked up, it would/should ignite. That would evaporate the water and send it out the exhaust.
It is a cup or more of water, I could see why it wouldn't start. But I'm only talking about maybe two table spoons.
