New member here! Having some issues with the B&S Intek 20hp in my Ariens mower. The model number for the engine is 406777, type 0442B1. I had a surging problem, so I purchased a new carb. It appeared to be identical, except for the fuel solenoid. The OEM one was on the bottom of the fuel bowl that operated in a vertical motion. The new carb had a solenoid that was horizontal. I just assumed it was a modification for something that was an issue with the vertical one. Installation was easy, and upon attempting to start it, I had to use ether to get it to fire. Once it was running, it had the same symptoms as the OEM carb. I decided to remove the fuel bowls from both carbs and compare. In the OEM carb, there was a plastic part that fits over the plunger. The new carb didn't have any such part. There was a metal shaft built into the fuel bowl, with a rubber o-ring that was crushed during assembly.
I can't seem to wrap my head around how the horizontal fuel solenoid works to shut off the fuel. Can someone here offer an explanation, or maybe a diagram of that particular carb so I can better understand how it works? Seems to me that it's missing something.
Thanks!
Thanks!
