Mad Mackie
- Jul 11, 2011
- 50
- 1,851
Due to the design of the deck, the right front caster wheel is set farther forward than the left to allow clearance.
Steve0853,
Here are the basics of correct Scag deck leveling.
Flat and level area to place the machine on.
Correct tire pressure.
Position the deck height adjuster in 3 1/2" position, unlock the deck.
I measure the actual blade height with a small tool that I made up. I will take a pic of it and post it, I'm not sure where it is at the moment, tool boxes are in my trailer.
Clean or new blades installed.
The front deck hanger levers are a fixed unit. Basically one piece as far as we are concerned, no adjustment other than the fine adjustment on the left front chain.
The rear hanger levers are independent from each other, and are held inposition by the rods that connect them to the front hanger levers.
The rear of the deck are the only leveling adjustments. Moving the nuts on the rods will change the adjustment.
Position the outboard blades forward and check the height at the blade tip forward and aft.
The forward facing blade tip should be 1/8 to 3/16 of an inch lower than the rear facing blade tip.
When you have performed these adjustments to both sides of the deck, and know the blade height, then you adjust the height to match the adjustable stop by turning the short rod. Raise up the deck to lock it and make sure that the deck up stops are not stopping the deck from locking in the up position.
You may need to reposition the deck height position pin to more closely match the actual blade height and readjust the short rod so the deck will lock in the up position.
