It was a humourious way of trying to say if we don't know what we are dealing with we really can not be of any help
I note that Mark asked you for the minimum basic information that is needed to start to diagnose your problem over a day ago .
You have managed to make 2 further posts but no attempt to answer Marks questions .
Now I could write a 10,000 word post outlining every possible cause of every engine ever made failing to run , how to test for it & how to fix it .
But I am too lazy to write it and most other people are too lazy to read it
All we know is you have a battery start engine with an unknown number of cylinders in an unknown configuration made by an unknown factory fitted to an unknown brand of machine which could be a ride on mower or a walk behind , a tractor or a ZTR you fitted an unknown brand of carburrettor and cranked the engine till the battery went flat .
You had the option of posting in a mower brad specific section or an engine brand specific section but you chose to use the non specific "brands" section.
We are not mind readers and have nothing to work with but the words you typed into your post which is SFA good for even making a reasonable guess let alone an informed diagnosis.
We can not help you if you will not help us .
And as you want to find offence with what I type then I will happily grant you your wish by adding you to the ignore list so I won't offend you again
Have a nice day
