jdunn618
- May 17, 2022
- Threads
- 4
- 36
I had work done & I replaced plug, belt, fuel filter, carb etc. I was having level cut issues, and when the shop brought it back after that & popping the new carb on for me, it started right up & is level. Fast forward 2 days, it got warmer out but not hot, put it on choke as usual. Started for 1/2 second & died. Tried that about 3-4 more times, same thing- so I let it sit. Well I ended up killing the battery. Ran good before, I think its something with new carb but I know can't start it at the moment & it seems to be a gas/air mix problem. Idk its all new & cleaned. Shop is closed due to memorial day & I got peoples yards to cut. Any help before I call them tmrw & get put off another week
