- Nov 29, 2014
- Threads
- 64
- 24,718
Any sort of diagnostic abilityI need some help. I have a Kohler 24hp 7000 series on a Craftsman zero turn. This spring I took it for the maiden voyage mowing and ran it out of gas. I refueled it and it was missing on one cylinder. After some research I did a coil upgrade that didn't help. I took it to the local small engine repair shop where it has been for 3 MONTHS. They called to report that they changed the carb and the muffler and it is still missing and running hot. They recommended a new motor for $1,800. It has 70 hours and has been flawless and gently used. What are they missing?
Go to another shop or take it home & allow the tech here to walk you through proper diagnostics & repair.
