Mystik Lubricants
reynoldston
First time I have heard about it. Ams oil is the big seller around where I live.
Mad Mackie
Tractor Supply sells some Mystik lubes, but I don't know anything about them.
KennyV
Their Premium trans hydraulic oil is great, it is a comparable oil for Many tractor brands (listed on the back of the pail)... Use it in several of the larger tractors. :smile:KennyV
Carscw
We use it in the sand dredge. It is good stuff and is mesha approved.
davbell22602
What about using it in outdoor power equipment?
possum
The super heavy duty oils are real good in OPE. They are rright along the same lines as the old Rotella 30 weight before they dropped the gas rating and the current Rotella 10w30 and 15w40 5w40 etc.
davbell22602
Thank you. I will be buying some of this in the 5w-30, 10w-30, and SAE 30. Im getting of running to walmart to get and sometimes come home empty cause they take forever to restock the shelves in the Super Tech thats by Pennzoil. Plus cost of gas also in running the full size pickup too just for oil.
