shadetree#1
Do as bertsmobile indicates in pst #39. (so as to locate where the voltage is being reduced)
BUT!!!!!!!!!!!!!
Good to hear you knuckled down and started using a vom for testing instead of just guessing.
Voltage is kinda hard to see with naked eyes, best to use a electrical tester.
I cannot find any wiring diagram or owners manual on-line using the model number you posted so I'm just going by experience. (as a electrician, electronics tech and mechanic)
You can take voltage reading to try and determine where the other 6 volts or so is being reduced. I seen a post few days ago on another thread where a guy mentioned that sometimes a resistor is in SERIES with a solenoid on some lawn tractors to reduce voltage spike when the solenoid is de-energized. (if yours has a resistor that might be a 6 volt solenoid.
Since you say the N solenoid is now clicking I would think about going for a starter crank with the spark plug removed.
If you get a good crank install the plug and test and post the results and We can give you some hints to test further if it seems to be compression lock.
BUT!!!!!!!!!!!!!
