reynoldston
Lifting on a 2X4. First of all you lift on the 3.5 part of it not the 1.5 part. Next use a short 2X4, not much over 2 foot long. Then you need the braces that go to the floor. Its stronger then you might think but I wouldn't go much over 150+ lbs. Just think about it put a short 2X4 between two blocks with the 3 1/2 up and try to break it by jumping on it. I will say a 200lb. man isn't going to break it. I do it all the time at my camp to lift motorcycles or mowers. Now not the whole mow or motorcycle but the front or back. I have never had a 2X4 so much as crack much less break. Now also use your head and don't use something full of knots. Yes take a 1000 lbs. on a 10 foot long 2X4 it might just break.
