ILL borrow compression tester tomorrow any special procedure that needs to be done?Like both plugs out or squirt oil in cylinder ?Its been awhile!
Both plugs out, throttle WFO ( not choked ) dryI like to
I like to do it by jumping the trigger on the starter solenoid, so the ignition is off thus no spark.
You can do it again after squirting a little oil into the cylinder and revolving the motor a few time to distribute it. called a wet compression test.
Only old farts like me do this. A difference of 10% or more = bad rings.
You need something better than 75 psi for the engine to fire even allowing or decompression.
You might like to try shoving the piston down with a stick while you rotate the engine to check the rod & crank are still together
