djdicetn
- Sep 3, 2012
- 2,193
The problem is we have thousands of laws too many already. Instead of having new laws we need to get government's nose out of everybody's business. If I feel safe running my zero turn on a steep hillside and have no problem doing it why should you have somebody make a law to stop it? I cut hillsides regularly that are very steep as do numerous others that do what we do for a living. I have had my 222 on hills that it literally slid sideways. I have cut places that you ease it upwards and then ease it backwards to the bottom and ease it upwards again.
I have found one thing on the Kubota 222 that is a hazard that has to be worked around.
The fuel tank is on the left. Therefore the left rear wheel has far more traction than the right one. On a steep incline going down hill it is virtually impossible to turn right if you are not going very slow. The reason being when you pull backwards on the lever to turn right the right wheel will start to slide and the left one will still have traction. Then the natural instinct is to push the left lever forward and pull the right lever backward to make it turn sharper. When you do it will get very fast in a straight line.
The first time mine ever did this it was a definite near miss. I wound up running off a bank into a parking lot. Had it been a highway instead of a parking lot it could have been deadly.
I learned that when you put this mower on this type situation you have to run at a very slow speed and keep the hydra stats working so that the wheels work slow and not let your instincts to turn sharper take over.
jekjr,
I too am glad it was a parking lot instead of a highway!!!! Did you tell your wife about that incident??? I know everybody will think I'm a henpecked woosie, but if it were me and I told my wife there would either be a career change for me or a divorce:0)
