msinabottle
Pics are do-able... Not tonight in the rain, but very do-able.
The early '80's Lawn Boy's had a plastic 'shut off' valve, like a motorcycle's, with a big rubber gasket held against the valve arm by a spring-steel clip. Mine quite recently has started leaking right through the bottom of the valve when the valve is in the "off' position--I kept wondering why the tank was empty. The rubber gasket is a thick neoprene disk with four holes in it, two engage pins on the valve arm, the other two allow gas to flow down from the gas tank into the fuel line through a cut-out in the valve arm. I think in the 30 years I've had the beast the valve seat has worn a bit, so that even the new gasket I bought and put aside for the eventuality is too thin to keep the fuel from leaking. One thought is to make a neoprene 'shiv' to make up the missing thickness, another is to seal the old hole--I've had lovely luck with 'Seal All' --and tap in a new valve which could be serviced or replaced.
Thank you for the warm welcome, I will unleash the Nikon at first opportunity.
Best!
Best!
