Spectre332
- Apr 19, 2023
- 1
- 6
Mower started and ran fine last week. 2 days ago I tried starting it again and absolutely nothing. No crank.. not even a click.. and no headlights. Checked battery voltage and it was 12.4V. Fuse checked good. Replaced ignition switch but no dice. Used a screwdriver on the two posts on the solenoid with the ignition in the run position and it sparked like crazy so it’s definitely getting juice.
I can’t figure out how the solenoid is getting juice but won’t crank… and how no headlights ties into all of it.
Ideas? Trying not to throw a bunch of money at parts that aren’t bad…
