ILENGINE,
Initially, my printed Dixie Chopper Owner's manual states 0.040" for spark plug gap and I have used that for the last 22 years and engine worked. I have regapped new plugs down to 0.030" over the last few weeks as recommeded earlier in this thread.
Star Tech,
You are correct in regard to the NEW coils I have (kill tab is on the same side as the plug lead). I noticed that when I first got the parts but you can see that often the part numbers are updated (changed) as time goes along and UPdated parts are sometimes different in construction. The new aftermarket starter that I got has 1 fewer teeth than the original starter (In only 1 place did I see that the new starter that I got actually is an Acceptable starter for my mower.) I had no idea initially that this aftermarket starter had fewer teeth. It engages smooths as if nothing was changed. It seems to operate just like the 10-tooth starter that I had initially when it was cranking the engine. The different outside left me with no place to install the black cylinder (tilt switch) and that's how it initially caused me NO SPARK condition.
There are NO part numbers of any kind on the new coils that I received, but
see below on the part numbers I supposedly received.
The part number on the boxes of the NEW coils are CO41 (ab).
Plus, I am getting spark. How can you have spark and no combustion?? (I don't understand that fact if the spark is actually the problem. Please help me understand.)
Is it the difference in coil or that fact I don't have the kill tab closer to me on Cylinder #1 that is changing the quality of the spark to stop the engine from starting.
Do I need to flip the coil on #1 so that the kill tab is up? If so, how do I orient the coil on #2 (kill tab down?). The original coils were oriented opposite one another with regard to the kill tab. My printed Kohler manual states that the spark plug lead needs to be oriented to the outside (I'm interpreting that to mean away from the other cylinder,, toward the front of the engine, not just away from the flywheel). It does show the kill tab towards me on cylinder #1. So, I thought the spark plug lead orientation was more important.
I guess I will try to flip the coils If it is actually possible due to the length of the spark plug lead and see what happens.
I would like to confirm that my NEW coils simply won't work properly no matter how they are installed, so that I can return them.
If I tell the seller that I'm getting spark, you know what he will say: The coils work as promised.
My guess is that the original coils will work (as noted earlier I recognized no spark and that was apparenlty due to my improper orientation of the black cylinder that one of you identified as a tilt switch and it seems to operate properly.
Any help and explanations of why I have spark and no combustion would be greatly appreciated.
(I simply want to learn so I get my mower working and so I don't make future mistakes.)
Thanks,
Mark
I got these coils on eBay with the following assertions:
Product Specification:
Ignition Coil Fits for KOHLER 24-584-01S 24 584 45-S CH18 CH20 CH22 CH23 CH620 CH621
Replacement For Part Number:
Kohler:24 584 01-S, 2458401-S, 24-584-01-S;24-584-45S
Fitting the following Models :
**Fits for KOHLER CH18 CH20 CH22 CH23 CH620 CH621 CH640 CH641 CH670 CH680 CH682 CH730 CH732 CH740 CH750
**Fits for KOHLER CV17 CV18 CV20 CV22 CV23 CV620 CV624 CV640 CV670 CV675 CV680 CV682 CV730 CV732 CV742
**Fits for KOHLER SV710 SV715 SV720 SV725 SV730 SV810 SV820 SV830 |
