Update: I now have spark (using a spark tester), but now my battery is apparently too old to turn the engine over fast enough to start. I recharged it, but it started raining, so I sharpened the blades. I had the battery charger off only during the blade sharpening and just reconnecting the battery charger, it appears the battery lost power as the smart charged started re-conditioning the battery again. So, I'll get a new battery and make hopefully only 1 more update.
Question: Should I continue to use the spark plug gap (0.040") as my dealer recommended for my CV20? My dealer told me to use the spark plug gap for the CV22 for my CV20. It is one of the few (maybe only one) riding lawn mowers that has a recommended spark plug gap of 0.040 " (about 1 mm) instead of 0.025"or 0.030".
Over the last month, I initially had trouble with the starter, (had been getting worse for many years), so I changed the starter/solenoid when I could get the starter to start at all.. That worked fine after I installed it. When I couldn't get spark, one of my gas tanks (right one) apparently developed a hole where the main wire harness was routed.. My seat switch had been de-activated a few months after I got it as the engine was cutting off every time I hit a bump. Since I couldn't find any other switches (didn't know about the tilt switch) as it was not mentioned in the owner manual, I figured it had to be the coils, so I ordered 2, because the starter was working fine.. (In hindshight. I think it was just the mercury tilt switch that I had re-attached improperly after bolting on the starter-solenoid, that prevented my spark.).
Thanks again, especially for the added info on comparison between the CV20 and CV22.
Mark
Mark
