Baby steps here....... Both will or should richen it up.Without knowing the difference I did ream out the main jet in the Epray but because it even needs choke at idle I also raised the float level.
Make sure you have no vacuum leaks ALL around the carb and gaskets. Any intake manifold pipes it may have.
Could buy another Epray carb they are so cheap. Maybe you will get lucky with it. Buy from a different seller. Make sure 100% it is for your engine. Message the seller and ask if it fits yours prior to buying.
I would enrichen the pilot circuit first. Slightly bore out the pilot jet. Pilot screw if it has one. Then if needed raise the float height about 1mm only. Try to get it idling/starting and low revs first. Then if needed hone the main jet out just a touch.
