Jimmy the Lock
- Jan 4, 2024
- 118
I just don't how long the plastic engine shroud is going to hold up to the vibrations and the weight of the Donaldson air cleaner
Mine does not bolt to the plastic engine shroud at all.
It uses the 2 bolts the original air filter door uses... and there is metal that the bolts screw in to.
So the bracket is bolting in to metal that is underneath the engine shroud, not to the plastic shroud itself.
