- Nov 29, 2014
- 24,995
So does 11.234 mean your battery is any better than mine that reads 11.2 ?Berts you are just seeing things wrong because you are in the wrong hemisphere where the electromagnetic currents run backwards. In America (TM) they wouldn't sell a meter with three decimals of precision unless it had three decimals of accuracy! 11.234 V means just that, not 11.233 or 11.235. In Chinesium We Trust!
And it is real fun when I reply so the battery is only reading 11.2 that is way too low and most come back with NO IT IS 11,234 as if the 0.034 actually meant some thing.
I had one galah who was giving me grief because the coil resistance was low so I told him to push harder on the probes and tell me what the DVM read
After a couple or readings it went up enough to read in spec so I finished off with "There you go you have fixed it " and hung up .
