- Nov 29, 2014
- 24,995
You can not test a regulator / rectifier fully sitting on the work shop bench without expensive test gear as you would find in an electrical workshop that fixes TV's
You can check to see if it is working properly mounted on the engine
As Star said, it is a works so leave it alone or does no work so replace it situation they are not repairable .
In a mower workshop the usual method is to swap it with a known good one as that takes about 90 seconds to do .
What I am trying to get you to do is test to see if it is working so you know if the unit is faulty or the wires taking the power back to the battery are faulty.
On single wire rectifiers there was a ground strap that went from the right rear cowl mounting bolt to the single mounting bolt for the rectifier
It should go under the plastic blower housing directly against the metal crankcase then loop down& go under the regulator.
This wire shakes around a lot in use and is prone to breaking where the terminal is crimped onto the wire so you get a random make & break situation.
When I replace them I use double heat shrink over the terminal to support the wire .
