Thanks Bert. I will look for the grounding strap on Saturday when I get back to the mower. Any diagram of where that ground strap is specifically located would be an immense help to me. I could not find it on any of the Briggs exploded views or the John Deere site. Anybody know where the grounding strap is for a 2020 JD ZTrak 375R? It’s engine #44S9770045G1
B & S usually mount their regulators on the plastic dip stick tube, which being plastic is not grounded
Kohler mount theirs inside the plastic blower housing, same story
The rectifiers both use make the ground contact through the case so it has to be connected to a metal part of the engine.
B & S usually run a strap from under the rear blower housing bolt to one of the rectifier mounting bolts
The single wire rectifiers have it under the rectifier between it & the dip stick tube
The bigger 2 ( or more ) wire ones do the same thing to one of the two mounting bolts.
Now I do not have the technical manual for your mower so I do not know if JD used the original B & S set up or have the rectifier mounted to the mower frame
If it is mounted to the frame then undo the bolts clean them, the rectifier around the bolt holes and the holes in the frame
If mounted on the dip stick tube make up 2 new ground straps, one to the blower housing bolt & another to the starter motor mounting bolt .
Belts & braces
Kohler use either a wire strap or a flat metal bar in the bower housing, both are prone to fracture after prolonged use
